1 - 6 of 6 Posts
I have a recentley purchased PT pro model. I am getting very unreliable Heart Rate readings from it. Seems accurate at the beggining then I look down and it will read 220 or somewhere near there. Any ideas on what could be causing this???
I've noticed when I'm around electrical lines,I lose the signal often.
Do you wet the strap before putting it on?
Just a couple of ideas.
Hope you get it straightened out.
As another poster noted, the strap must be wet. Except on very warm days, water and sweat won't do it for me (I do wear a moisture wicking base layer). I just slap some Lubriderm lotion on the back of the strap at the contacts when I put it on. Now the readings I get seem very consistent and reliable.
I always start out with the strap wet, maybe it's drying off too quick. I will try the lotion trick and see if that helps.
Thanks
The PT Pro does not have a coded strap, so the CPU can pick up others' HR transmitters. I also think it is more apt to pick up interference from overhead electrical cables or electronic equipment.
I have a PT Pro on the bike I keep on my old Velodyne trainer. I had problems with it too. I ended up upgrading to a coded transmitter and CPU. The cost was $219, and Saris gave me a $100 credit for trading in my old CPU and transmitter. The new coded one is much more reliable and works much better.
1 - 6 of 6 Posts
