1 - 11 of 11 Posts
Sadly, since I am not one for posterity, I do not have a true 'starting' photo of this bike. Sufficient to say that it was in pretty rough shape. I drilled out the front brake and used an extra 105 front brake and switched out the wheels to whatever stock wheels came on my wife's Specialized (original wheels were cooked). I flipped and chopped the handlebars and used an extra aero brake, converted the rear tire to single speed (yes was ridden as SS with only front brake - pretty stupid) and used it to commute to work. One day I got around to taking a photo of the bike in my office. I'll attach that. Only real thing to note is the rust/marring on the chainstay/seatstays (even visible with my phone camera). The underside of the bottom bracket looked like it had been drug down a country road.
So after a wreck riding home one day I decided perhaps this should be rebuilt and be used as a fixed gear also. I also decided that the bullhorn look wasn't right for me. After some garage work and some taping and spray painting - this is what it ended up looking like. I like it and I guess that's all that matters. If I had to do it over again I would not have tried to paint the lugs a different color using spray paint - that was a lot of tape. But then again I have a 10 month old daughter so perhaps I was just testing out my patience.
duh...
pic 1- the straps on that bag are designed to go through the seat rails, from the middle, then out and around the bag, and then clipped underneath
pic 2- that's a good bit of slack in that chain
Carbon Fiber = Explode!
I second that chain comment.
But I think you need blue toestraps/powergrips, white saddle and you're good to go
true by two
1. Good to know - honestly that was from my wife's bike too and I couldn't figure out for the life of me how to get the slack to go away. I don't use it on a bike now but if I do in the future - well that saves some time.
2. Probably right. It isn't set all the way back in the dropout but even so it's a little loose. It is not totally ready for riding at this point so I will take a gander at removing a link or 15.
Baltic Scum
Do you have Popeye's forearms or just use that saddle tilt to slide onto the top tube when the chain falls off?
Nice grill.
Baltic Scum
Your title had me all excited about one of those old Austrian Puchs. Bummer.
Nice paint job, though.
eRacer
I am not usually a 'Blue' person, but I like this a lot.
Nice going
Discussion Starter · #10 ·
Sadly my upper body is built more like Olive Oils. Save for above the neck - then you're talking more like Brutus (or was it Bluto?). I'll finish off the analogy with the appetite of Wimpy and potentially the disposition of Popeye after a few brews.
I commute on a Reynolds 531 Puch painted Krylon blue.
I hope you enjoy yours as much as I enjoy mine.
1 - 11 of 11 Posts
