I'm new to cycling, have 150 miles this month logged on a new bike (Giant FCR 3) bought at LBS. The only thing I've changed out are clipless pedals.
Specs: http://www.giant-bicycles.com/en-US/bikes/women/1254/29455/
I've noticed for the last 50 miles or so that shifting up or down into specific gears seems to cause them to "hang" (for lack of a better term) then lunge when they finally catch.
I have no idea what the correct terminology is, but here's my best description of what's happening:
I'll be in the middle gear of the crank (2 on the left shifter), and I'll want to shift up or down into 3 or 4 on the right hand shifter. It will often make a chan-ga-chan-ga-chan-ga-chan-ga noise when I attempt this specific gear range. I can lightly press on the right hand shifter to drop it down into an easier gear, click up to a higher gear, OR if I don't change the gear, it will continue to make noise then spontaneously lurch into a lower gear throwing my cadence off or worse (dangerous riding when not in control of the pedals).
This results in me doing a changa-change shift up down up down lurch dance when going up hill. Not fun.
Is this a mechanical issue that my LBS can fix, or user error on my part not properly shifting? If I hear that changa-changa noise, does that indicate something is wrong?
Thanks for the help.
