1 - 16 of 16 Posts
so - finally my (cx-ray) spokes are arriving tomorrow. I figure I should start easy which would be the radial 20 front (90mm rim)
so - the question is - heads in or out? novatec hubs...
wheelbuilder
Depends on the hub. When you do radial heads in with some hubs you can distort the hub enough under tension to allow for premature bearing wear. I have the most confidence with Tune hubs. With White Industries and DT, I and others I've talked to have had this happen. I prefer a crossed pattern with those hubs.
-Eric
Cpark
Heads out but check out the hub flange width and the fork clearance before you are committed.
Zen built me a pair of Edge 45 w/Alchemy hubs, and I can use it on my Serotta Legend Ti & Time RXR but it doesn't have enough clearance on my VXR Proteam.
Check out the hub flange width of Elf and Novatec ....
What fork are you using?
Cpark
Just check the f to f width of Elf is at 82mm while all the Novatec f to f are 72mm and less.
You should be ok in regarding the clearance.....
'brifter' is f'ing stupid
i know zen is all about heads in, but it's pretty rare. i agree w/ the other poster about possible shell distortion depending on the hub. take a look at 10 different radial front wheels, you'll prob see 9 are heads out. we build all ours that way. i don't think you're gonna lack any stiffness w/ a 90mm rim.
So a question about heads-in. Will it make a difference in my spoke length calculation. Maybe add a mm? I never lace my front wheels radial, but I am building up some carbon CX tubular wheels and am going to lace the front radial.
It may seem like a stupid question seeing as you don't need two different spoke lengths on any given cross pattern laced wheel, but I just don't have the experience.
1 - 16 of 16 Posts
