rcnute said:
Yeah, 25 years is unacceptable!
Will modern derailleurs usually fit wider six-speed chains or is it hit and miss?
Generally speaking, yes. But since chains tend to be the lower priced component (and have less service life), I tend to think of it in opposite terms: is the chain compatible with the other drivetrain components.
Six speed chains are compatible with drivetrains up to 8 spd and measure about 7.1mm's in width. The 10 spd Shimano RD cages measure (approx.) 10mm's. That given, I think you've got much better odds of 'hitting' than 'missing'. BTW, FWIW there's only about a 1mm difference in chain width going from 6 spd to 10 spd - 7.1 to 6.2mm's.
Of course, if your chain is as old as your 600 RD, you
may want to spring for a new one.
