1 - 5 of 5 Posts
First post on this site. I am trying to decide between the Cannondale R5000 and R5000 Compact Drive. Thoughts? I typically ride 25-50 miles per night during the week and longer on the weekends. I live in New England, so a fair amount of hills. The local bike store explained the compact/triple choice, but I am still confused with what to choose. Thanks.
buy a compact. simple as that.
now my explanation:
they're flexible. with a combination of cassette and chainring selection, you can select such a huge range of gears, and as you progress as a rider you can change your drivetrain to match.
for example:
one person i ride with bought a compact because they had difficulty making it up hills but didn't want the hassle of a 3 chainring bike. he runs a 34-27 low gear and can spin up pretty much any climb (i live in lower CT, short steeps everywhere).
another person i ride with is buying a compact and running a 34 chainring with a 11-21 cogset. This gives him a low gear equivalent to about what a standard bike comes with, BUT his gear ratios are extremely close together, so is much more efficient. he kicks my ass, btw.
with a standard ring you're stuck. if you want a lower gear you have to sacrifice gear ratios. if you want better gear ratios you sacrifice by having too high of a low gear.
compact is the way to go.
Depending on your riding ability if you think you are capable to attack those hills then get a compact version otherwise I would pick triple crank set, this option give you more option to pick and choose your gear selection, and you have ten extra gears to play with.
Ten extra gears? Have you ever tried a 30-12 combo?
In reality, a triple would give you 13.3% lower gearing than a compact with a 34T inner chainring. If you ran a 27 rear cassette on the compact, the difference would be 4.9%, which is hardly anything.
If you need a triple and a 27 rear, you need to practice more. Or get a mountain bike.
I'm with ctracer01's - I've put over 5,000 miles on my Tarmac in the last year and I love my FSA compact. At 5'10" 175# i'm not a lightweight but I've been able to climb over 7500' and feel fresh with the compact.
My last bike was a triple which I'll never do again. The 30 ring is too low, and the 39 ring is too large for hills. The 34 compact lets you have a good selection of ratios to climb from 6 mph to 14-15 mph.
The OP rides 100 miles+ a week, so I'd go with the compact.
with triples you're carrying around extra weight and get poor front shifting in return. with compacts you can go as low as a 34t in the front and with little searching you can get any chainring combination you want all the way up to a 42/56. you may be saying what about the granny gear on the front to get up the really steep stuff. if you have to go much lower than a 34 up front and a 29 in back you're probobly going so slow you're at risk of falling over. with regards to a standard crankset which are normally equipt with a 39/52 there you are limited to 38 or 39 teeth for your inner ring and don't have the flexibility of a compact.
1 - 5 of 5 Posts
