1 - 3 of 3 Posts
Can you run the new 8170 brake caliper with the older model 8070 brake lever? I want the clearance of the new calipers, but don't want to buy new brake levers too..
Note that the extra clearance is 10%.. of 0.5mm. That means that instead of 0.5mm of clearance, you'll then have 0.55mm of clearance.
Every little bit helps, but don't expect it to magically solve all your problems ;-)
1 - 3 of 3 Posts
