I had an Axiom SL built in 2013. The LBS built it up with Campy Record 11. The bike was great except I was disappointed that my old '95 8 speed Record was a much more precise shifter. I chocked that up to progress.
After more B adjustments by LBS than I care to remember, I finally found a really good Campy mechanic that discovered the Seven's rear derailleur hanger is placed to work with Shimano/SRAM but not Campy. He contacted Seven and learned that all frames are shipped to the LBS with a Campy adapter. The problem is that the LBS that is the sole Seven shop in my city forgot to include it in the build. They also used the Campy front brake bolt instead of the one Enve provides. Braking is now much better no thanks to LBS.:mad2:
