With a singlespeed chain, I could care less but since the tolerances are so tight on a 10 speed chain, i'm unsure.
Recently bought a campy record chain, compact campy crank and a new cassette. Did the measure 3-4 times and cut once thing but the chain must have been caught up on something as it ended up being long enough that there was slack in it. So, I found the original pin I pushed through by verifying the guide pin fit into it, backed it out the same way it came in and then re-installed it after cutting to the proper lenght.
I just want to know if this is safe to ride or if it will blow apart on me on a sprint or while 40 miles away from home. There is a bit more side to side slack in this link than the standard ones, I'm not sure if campy pins/plates are designed to only work on a one time push.
