BoootyHoIe said:
Well all I'm asking for is what brand of Road Bike should I get?
I am a newbie to Road Cycling so help me out!
There the specifications on like 20-speed or 12-speed whatever that is, which I need info on what the heck that is too. =D
How can I choose the right Road Bike? Also, what bikes are you guys personally using? I'm looking for a Good/Pro bike that's affordable. 1,000 Range.
There is no "best", there is no "right", there is only what you end up choosing and later deciding if you still like your choice. What is best and right today might not be best and right once you get a few miles on your legs and cycling.
You have set a budget, that is good, but does that budget factor in accessories like shoes and helmet and gloves and a multi tool and a seat bag to carry stuff in? Will you want to ride in street clothes or will you want to get all lycra'd out? Are you looking at using the bike for road racing, and if so will it be criteriums or road races or time trials? Are you going to be using the bike for commuting, or general exercise and just riding around for fun and for something to do?
The better you form parameters of what you're looking for the better your final decision will be. And if you don't have any or many answers yet then just provide what you do know so far.
With all that said I will submit one question to you:
1. Do you prefer or want or desire:
1.a. Steel frame and forks
1.b. Aluminum frame and forks
1.c. carbon fiber frame and forks
1.d. a combination (such as a steel frame and a c/f fork)
1.e. other
1.f. No preference or don't know yet or haven't formed an opinion yet.
I will also submit one additional question for you:
2. How do you intend to use the bike: (you can pick more than one answer)
2.a. racing (and what format(s) of races do you want to do)
2.b. commuting
2.c. utility cycling (getting groceries, running errands, weekend escapes, short or long touring, other)
2.d. bar hopping (did you recently loose your driver's license and now need a set of wheels? Hey, it's real reason some have.)
2.e. other (fill in the blank)
20 speed and 12 speed are ways to describe a multi-geared bike. Back in the old days there was a 10-speed which had five cogs on the rear wheel and two chainrings on the cranks so 2 times 5 equalled 10. These days many people will just count the rear cogs, so a 7-speed will have seven cogs on the rear, then they'll factor in how many chainrings are on the cranks (usually two or three (aka: a triple)). Many people these days no longer do the math to figure out the total possible gearing combinations, so no more 7 x 3 = 21 stuff. Well, some still do the math, and that's okay, but I don't, and that's okay too.
Your next step, and really the only way to know first hand, is to borrow bikes from friends or relatives or visit bike shops and test sit on a whole bunch of bikes so you can begin to get a feel for how the different general geometries feel. Some bikes are set up to put you in a very upright and compact riding position, others will put you into a very bent over and stretched out position. Only you and your answers to question 2 will determine what style of geometry will work for you. There is no shortcut here, you have to put in the work, otherwise you will just have to accept what you get if you don't take the time to do this.
Consider cars instead of bikes, there are pickup trucks and vans and station wagons and SUV's and sportscars and SMART cars and a whole lot of variations within each general category. For pickups there are 2-door, 4-door, short bed, long bed, standard cab, extended cab, 2 wheel drive, 4 wheel drive, dual and single tires on the back, 1/4 ton, 1/2 ton, 1 ton, 2 ton capacities, and hybrid engines and diesel and gas and 4-cylinder and 5-cylinder and 6-cylinder and 8-cylinder and 10-cylinder engines, there are V-format engines and straight engines. What you get really depends on what you want to use it for and what you feel or think you'd like best to have. I can't pick your pickup for you because I'm not the one who will be driving it. Now if you want to buy me a pickup then give me a 3/4ton cab and a half with an 8'bed and 4wheel drive and a manual tranny with a full trailer towing package including a trailer brake controller, even if I don't put more than 5,000 miles on it in a year that pickup truck format will do 99.5% of everything I'd need a pickup for.
Hmmm, this became book length, so I'll stop here before someone whacked me with a greasy pedal wrench.
Hope this helps, and if not then I hope it didn't hurt.
