1 - 20 of 51 Posts
This is a question that’s been on the back burner for a while now. Thought this would be the perfect time to lay it out here.
1. Rear derailleur works by the pulley moving across the width of the cassette. The cable pull is regulated by the amount of cable pull within the shifter mechanism. What’s stopping me from using a older model 8 speed derailleur with a 11 speed shifter? Or a 9 speed? The cassette hub is a constant fixed width. The only variable is the spacer width and the cog thickness. Theoretically, setting the high and low limits should take care of that. Let’s have the yay’s and nay’s on why it should or shouldn’t work.
'brifter' is f'ing stupid
8, 9, and 10 are the same cable pull ratio...except for 4700. It's 10 speed but the cable pull is the same as 6800/8000 and 9000/9100. You can use the 8 speed derailleur w/ any 8 or 9 speed shifter, and all 10 speed shifters except 4700 Tiagra. It won't work w/ ANY 11 speed shifter. You can use the 8 speed derailleur w/ any 8 or 9 speed mtb shifter as well, but no 10 speed (Dyna-Sys) shifter will work.
As others have noted, as long as the cable pull is consistent then it will work. But when you say "older" derailleur, you might find that a newer 8s derailleur will work better than an older 8s derailleur just because there are improvements in derailleurs over time. Might not be an issue in your specific application.
So, how exactly are you going to get to 9,10, & 11 speed gears? ... when the shifters only go to ...8?
I think you're going to be missing some gears!
Reading comprehension issues or trolling? The OP said "8 speed derailleur with a 11 speed shifter"
OK, I got it backwards. I guess I got mixed up with another thread about/with a 11 spd hub/wheel.
Banned Sock Puppet
Exactly this. Shimano changed the cable pull ratio on 11-speed road and 10-speed mountain to pull more cable.
Unless this 8-speed rear derailleur is one you have lying around your bike parts pile, why would you want to buy an 8-speed one when 11-speed rear derailleurs are relatively cheap anyway?
Discussion Starter · #9 ·
I think you misunderstood me. The shifters will be the change in the constant. If I use 11 speed shifters with 8 speed Dura Ace rear derailleur, the cable pull will be regulated by the shifters themselves. If the hub width remains a constant as well, wouldn’t the 8spd rear derailleur work just as well?
Discussion Starter · #10 ·
Lockdown blues and boredom. I have an old DA 8 speed derailleur in the spare parts bin. Will update if my theory holds or not as the case maybe.
Banned Sock Puppet
No, an 11 speed road shifter has a different pull ratio than an 8, 9 or 10 speed. Any 8, 9 or 10 speed road shifter will work with any 8, 9 or 10 speed road rear derailleur (unless it's Tiagra 4700). However, the 11 speed road system pulls more cable per shift and therefore is not backwards compatible.
I'm still not sure what you are trying to do here. What do you have on your bike as far as shifters, rear derailleur and cassette and what is it you are trying to change?
Nope. The cable pull is regulated by the shifter but not how much the derailleur moves. That's a combination of cable pull and derailleur geometry.
Discussion Starter · #13 ·
Like I said, lockdown boredom and the fact that I have an old 8 speed kicking around. Believe it or not I have managed to get a 10 speed Rival derailleur work with a 9 speed cassette with help from 9 speed Campy Daytona. I will keep you updated on this thread as to where the boredom driven rabbit hole leads me. ‘Tis curiouser & curiouser said the bunny wabbit
Banned Sock Puppet
Like I said, lockdown boredom and the fact that I have an old 8 speed kicking around. Believe it or not I have managed to get a 10 speed Rival derailleur work with a 9 speed cassette with help from 9 speed Campy Daytona. I will keep you updated on this thread as to where the boredom driven rabbit hole leads me. ‘Tis curiouser & curiouser said the bunny wabbit.
Haha! OK. Not sure about SRAM compatibilities. I'd have to look that up. CXWrench would know for sure. But hey, if you're bored, try 'em all, LOL! :D
If that's true then theoretically an 8 speed der will over shift because it was designed to move further with less cable being pulled.
Try it to find out. "more" cable being pulled doesn't necessarily mean it's not still be 'close enough', It won't be perfect but wouldn't shock me if it worked acceptably.
Super Moderator
Yep. Metaphorically, the derailleur is the big dumb boyfriend doing all the heavy lifting while the shifter is the cute girlfriend calling the shots and telling him where she wants the furniture placed.
Banned Sock Puppet
Yep.
Hahah! Good analogy! :lol:
Kind of the opposite in this situation. Instructions on placing the furniture are a given.
The cable pull from the shifters is what it is no matter what. Different ders make different decisions on placing the furniture with the same instructions.
Super Moderator
I think we're on the same page: The "instructions" are coming from the shifter-dictated cable pull/girlfriend, and the actual shifts of chain are being performed by the derailleur/boyfriend, yes?
[Of course, IRL, the actual girlfriend is continually updating those instructions as to where the furniture is to be placed, sometimes in boyfriend's mid-lift, so the metaphor isn't perfect. :) ]
Discussion Starter · #20 ·
Update: I am going over the deep end because of lockdown related nuttiness. I have decided to mess around with my 29er first. Now, I know there are going to be a lot of indignation that I am introducing a (gasp) mtb onto a road bike forum but hear me out. This is a investigatory phase 1.
I am going to replace my well designed and tested Shimano XT/XTR components with Chinese components from Sensah.
Currently, I have 2x setup. I am jumping to 1x and 11 speed. Got the cassette, chain and brake set. Waiting on the shifters. Will update after install and provide feedback. Besides,it can’t be any worse than SRAM.
1 - 20 of 51 Posts
