1 - 3 of 3 Posts
Not sure if this should go in the beginer forum or this one...
Sequence for changing a rear tire.tube on a single speed bike (specialized langster)...
Do I unhook that clip on one of the chain links, and somehow push out the pin, freeing the chain as the first step?
· Done with winter.
Put rear wheel all the way forward in the drop-outs... lift the chain off the cog, on to axle... pull wheel back and slide chain off the end of the axle as it comes out the rear of the drop out.
No breaking of the chain... unless you run your wheel so far forward in the dropouts that you can't get it forward enough to slide the chain off ... if that is the case you should add a link to move your wheel further back in the drop outs.
1 - 3 of 3 Posts
