1 - 7 of 7 Posts
I have a 32 hole record rear hub from like 03 or 04.
I want to build this onto a 28 hole rim.
What I am thinking is this.
On the drive side use all 16 holes 2 cross. On the non drive side use every other hole
in a 1 cross.
What do the more seasoned builder think of this.
Brian
what? that's 24h not 28?
if that's what u meant... dooo it. i have into a 24h AC420 rim, and i quite like it.... more difficult to balance than a convential setup tho...
tension worked out really well... around 105kg DS, vs ~95kg NDS.
Banned forever.....or not
It will only work if you can move part of the wheel into the 4th dimension.
1 - 7 of 7 Posts
