1 - 5 of 5 Posts
No - Record, Chorus, Centaur skeletons, and in the case of the picture, mavic ssc - all campy brake calipers expand by pushing a button toward the outside where the brake levers meet the black rubber shrouds - right above "Chorus". It makes no difference what kind of brakes you have on the other end, Don't forget to re-set the buttons when you're through.
Best way to center brakes is to use a thin cone or open end wrench to center the brakes. Then tighten the allen nut from the other side. Re-adjust your pads after you do this. There may also be fine tune adjustments as per the instruction sheet, follow them.
1 - 5 of 5 Posts
