1 - 20 of 30 Posts
Has anyone on this board had surgery to remove their hip hardware?
I've had a pin and screw in my right hip (femur) since 2003 from an mtb accident, and will finally be taking everything out later this month. Specifically, I am interested in hearing what kind of recovery you had post-surgery.
The hardware pretty much looks like this: https://www.positive-way.com/recovery/images/my-hip-front-view-closeup-of-pin.jpg
Both surgeons I talked to indicated that the surgery would take less than an hour (full anaesthetic), and that I would be full weight bearing and walking out of the hospital the same day. I've been told to "take it easy" (nothing extreme) for 6-8 weeks so as not to break the hip again, but otherwise no restriction on activities/cycling. I will be setting the bike up on the trainer before I check in to the hospital.
Any comments or advice on recovery are greatly appreciated.
Thanks.
I've got the same implants. I broke my hip in '05. They don't bother me and I never plan on taking them out. I presume you had problems with yours?
Roll Out Jeremy
Hip Replaced
At 52 yo I had a total hip replacement. That was 3 years ago. It was a really good thing to do. It is completely pain free and as strong as ever. They cut one muscle for that surgery. That made recovery a little more intense. Removing your hardware should not involve cutting a muscle (ask your doc). If that is true it should heal up easy. I have no restrictions from the THR.
I like waterboarding...
Back history: broke my femur, and chipped the side of my knee off about 10 years ago.
Surgeries
1st - remove the screws through the knee (they were causing mobility issues. About a year post accident.
2nd - remove hip fixation screw holding the top of the rod in place. Caused pain for many many years (Dec 09)
3rd - knee resurfacing and medial shelf issues (dec 09)
I had the 2nd and 3rd surgeries performed about 2 weeks apart starting at the beginning of December. I was snow boarding on the family vaca Jan 14th without any problems...
The hip muscles will be a little sore depending on what they have to do to gain access to the fixation screw. You shouldn't have any mobility problems as they are not messing with the joint itself. I took one day off work post surgery to hang out around the house and rest. Was back at work the next day on crutches, which i really didnt need. The following day (3) after the surgery i was walking unassisted with a tiny gimp. by the end of the week all was good.
I'd give it two weeks before resuming any light exercise and then just slowing increase the amount of exercise... You should be back and running in less than a month.
Edit: Are you keeping the rod? I still have the rod and two screws above the knee. I opted to leave the rod in place since it was fixed at the top of the hip and bottom of the femur. If you only have a fixation screw at the hip holding the whole setup together they will pull the rod for sure, but if you have hardware above the knee the rod will likely be left in and they will only take the hip pin out.
Discussion Starter · #5 · (Edited)
Yes, the pain in my hip while cycling has gotten worse in the last 1.5 years. It's only at high intensities, but I climb a lot and it usually starts to bother me about 15 minutes into a climb.
I had the screw in my knee taken out in '04 because it was bothering me, and later had the option to take out the rest of my hardware. However, I wasn't too anxious to go under the knife again and wanted to see how it went.
It took three years for me to be able to ride hard again, and I had 2-1/2 decent, relatively strong years before things started to go south last year. In addition to the hip pain getting worse last year, I developed a clicking sensation in the knee (same leg) and can't really drive hard on the climbs. I've done physio/sports med and had a fitting, which improved the pedal stroke/knee tracking issues I was experiencing, but the surgeon feels there is good chance that removing the hardware will improve the hip pain.
Quite frankly, I'm looking forward to the surgery, and being able to sleep comfortably on my right side again. (Right now, I feel the screw when I sleep on my right side.)
Thanks a ton for the advice.
Snowboarding is also at the back of my mind, as I need to decide this month in order to get our season's passes.
I also had the screw in my knee removed after one year, I could actually feel the screw impinging in that area and I'm glad we acted quickly to take it out.
There is only the hip pin and one fixation screw left (top of the hip), so they will be taking both out.
I suspect that next year I will be moving on to address issues with my knee. But either way, I'm glad to be moving forward so that I can really hammer climbs again.
sanrensho said:
Quite frankly, I'm looking forward to the surgery, and to being able to sleep comfortably on my right side again. (Right now, I feel the screw when I sleep on my right side.)
This was exactly the same reason I had mine removed. For 7 years I couldn't sleep on my right side. Was horrible, and frankly, im amazed now that i put up with it for so long.
I also had the same problem with the screw grinding against the muscle when climbing or pushing really hard on the flats. I learned to live with it for so long. Then one day i got a hair and wanted all the **** fixed lol.
My knee clicks and pops on occasion and if I get it in a funky angle while powering on the bike its uncomfortable but its livable. I'm sure knee replacement is in my future based on how badly i damaged my knee.
Discussion Starter · #9 ·
Yes, I'm being told that they will not need to cut any muscle. Great to hear that you are doing well with the THR.
Discussion Starter · #10 · (Edited)
mymilkexpired said:
Have you had an MRI of your knee?
We haven't had an MRI done yet, and I suspect it might take a few months to arrange once I'm in line.
To my knowledge, I didn't damage my knee in the original accident. (My front tire slid out on an S-turn, I landed softly but squarely on my right hip, heard a snap, and that was all she wrote.) But last year I started to develop a constant clicking sensation in the knee, both while riding and walking up stairs. Like you say, it's livable (but feels weak) and my sports med doc doesn't feel that I am doing any damage by continuing to ride on it.
I guess I'll be seeing my sports med doctor this winter to look further into my knee.
I have no input on this subject, but I had to say... This thread is full of *cringe*. I am in pain just reading about your stories. GLTY in teh surgery.
Same here, I couldn't sleep on my right side and I had them removed ASAP. I would roll onto my right side and the pain would wake me up at night.
Titanium screws.... (check out the new penny, I only noticed that recently).
Discussion Starter · #15 ·
You kept the pin in?
The hip screw is absolutely the worst for camping (sleeping on a thin pad).
Oh I don't recall them putting in a pin, just the 3 big nasty looking screws.
This was also a result of a mtb fall, those bikes are dangerous. :)
Discussion Starter · #17 ·
D*mn right, I will take suicidal squirrels any day.
mymilkexpired said:
You may have a shelf or a plaque under the knee cap. My December knee surgery involved a plica issue and the trimming of some of the cartilage for pain in the knee.
Thanks, will definitely look into this.
It's not easy being green
Dude, it's no big deal. In 1985 I got thrown off a horse into a phone pole, had a hip fracture fixed with a Richardson screw, looked just like yours, a plate up the femur into the hip ball. A year later I had the thing taken out. It was like two pounds of hardware. The surgery was nothing and I was walking that day. It will heal stronger without the screw when the bone fills in. I unfortunately had muscle cut when the fracture occurred that has never grown back, but the removal was easy. Just remember to ask for demural and not morphine! You'll be riding in no time.
Moderator
Hmmm, I never thought of the weight weenie aspect of the internal body hardware. Maybe I should get some of it cleaned out to help my hill climbing! I have the same femur stuff which has been there for 11 years (roller blading), and more junk in my arm that is 12 years old (snowboarding).
Good luck
I guess I'm lucky. My compression screw bothered me for a couple of months. Now I have no problems sleeping on my right side. It did take more than a few years to get total strength back in my injured leg (I have a ti rod in my femur). I do a lot of climbing also. After almost 5 years I can now get out of my saddle when I climb. I can't run at all. I can walk, just no running. Breaking a hip is brutal. Hope I never have to repeat it. The best part is I had a great surgeon and my health insurance covered everything.
Dental implants are another animal. 2 implants, plus the crowns, cost me a trip to Hawaii (or a new bike). $7,000. By the way- Gatorade is really bad for your teeth.
Good luck. Let us know how you progress.
1 - 20 of 30 Posts
