A friend of mine had a Force crankarm do that a month ago.
I was just told that it was out of warranty and that I could buy a new one. The non-drive arm is more expensive than a new take off rival crankset, so I just bought a whole new crank so I could start using my stages on the road bike as well as my cross bike.Did you contact Sram about it?
I would still contact sram about this!!! It is clearly a common problem. I mentioned this to some of the guys I ride with and it has been seen before! suppose to be a bad batch....I was just told that it was out of warranty and that I could buy a new one. The non-drive arm is more expensive than a new take off rival crankset, so I just bought a whole new crank so I could start using my stages on the road bike as well as my cross bike.
I didn't gather any more info than that, I'm not sure how common it is or anything. It's not the first less than normal thing I've broken on a bike so we just chalked it up to me being a big dumb animal on a bike.
My LBS contacted SRAM directly about this and what I typed was SRAM's response. I'm sponsored by the LBS so I consider the information from them pretty reliable. Maybe they consider it a wear item, I'm not sure. Sram has been pretty good about other warranty items but I don't feel they're obligated to replace this. I do hope they are working on fixing the problem though if there are so many of these occurrences happening.I would still contact sram about this!!! It is clearly a common problem. I mentioned this to some of the guys I ride with and it has been seen before! suppose to be a bad batch....
