I need to shorten a SRAM hollow pin (PC 89R) - can I use a normal chain tool?
Yeah, I always go with the big/ big, and let the small/small fall where it will. Never has a problem.Mike T. said:You've got it all back-arsewards. The most important thing is that there is enough chain for the big-big combo. Failure to do this will result in equipment damage if that combo is mistakenly used.
This is easy to figure - SRAM says this ~ run the chain around the big-big without going through the derailer, match up the ends and add two links (1").
The downside to this is that you may get some chain droop in the small/small combo - much better than a bent derailer.
I'd rather avoid the small/small combo than the big/big anyday. How many of us haven't shifted into big/big by mistake in the heat of the moment?
Not that C-40 is wrong. What he says is right if your are switching cassettes and and using out of spec derailers. I have just never been a casette switcher, and if I were to do it, I would always check the big/big 'just in case'.Cory said:It's really dumb that you can't (nm) in the new format.
You can. Just leave the Title box empty and put your (nm) message in the body. Try it in a reply to me.Cory said:It's really dumb that you can't (nm) in the new format.
