1 - 11 of 11 Posts
For years I have been using an 8 speed chain. I have never had a problem removing the master link before. Today I installed a new chain. The master link went on without a problem. I wanted to remove the chain to take out a link. I cannot remove the master link. I tried squeezing it while sliding. Nothing seems to work. I hesitate to use tools because I don't want to ruin the chain. Any advice will be appreciated it.
Huge in Japan
Looping a piece of brake (or break, which ever you prefer) or shifter cable around it and pulling the ends to compress it can work.
Yea, just buy the tool. It's not expensive and will soon pay for itself in reduced aggravation. It's definitely a tool worth buying, I think.
You can use any old pliers although even a cheap pair of slip joints are nicer than electrical pliers. Squeeze opposite corners and they will pop apart, the reverse to close them. You could probably improvise with 2 rocks on the trail if you had too.
Here's a guy doing exactly that.
As was mentioned, the older 8-9 speeds were easy by hand, the new chains are essentially impossible.
1 - 11 of 11 Posts
