what's the best way to remove the clear coat covering the carbon on my frame,so i can re do the frame to make it all beautiful again ?.
Gee! I don't know. Can I trust you to difinitively say that it will be detrimental? Have you tried it & had a bad experience? What type / brand did you use? What happened to the CF you used it on?the bull said:No No No!!!
That is not good for carbon!
Do you really trust some bonehead at a auto paint store to know how there materials are going to react with carbon?
shabbasuraj said:I have done exactly what you are planning to do.
Results were amazing.
If you wish to just remove the clear coat to remove decals, a fine grain sandpaper will do.
If you wish to remove the paint also, then I would recommend a random orbital/fine sander with 80 grit, while working up to a finer grit for the best results.
good luck.
yes......martyn bruce said:did you use the fine paper on the carbon?,
