1 - 4 of 4 Posts
Converting an old schwinn into a fixie and want to remove the shifter bosses/brazeons or whatever they are. Any recommendations? I plan on having the frame powder coated so I would like to remove them first.
Braze on removal
Just did that last week. Apply the heat to the shifter posts, not the tubing. work the heat around post to heat evenly. Use a pair of pliers to pull/twist off the posts. Clean up the remainder of the brazing with a fine tooth file and then sandpaper. I used a oxy-acetylene torch in order to concentrate the heat on the fitting, not the tubes. I did the same to remove the brake guides as well. Go slowly, if you heat the tubing, you can take the heat treating out of it.
Strip the frame & repaint.
Cool. Thanks for the info.
I would think that you could take them right off with a dremel. Maybe sand smooth and fill (and sand again) before sending for color?
1 - 4 of 4 Posts
