1 - 4 of 4 Posts
Hello all,
I have a Giant TCR Advanced Carbon T800 frame, as shown below:
http://www.wiggle.co.uk/images/giant t mobile tcr comp frameset.jpg
I do not like the magenta on the front of the frame as I am a guy, even though its a mans bicycle. How would I go about replacing the pink/magenta with a different colour, like a deep blue - taking note of the carbon fibre frame.
Thanks in advance :)
I'd suggest sanding the entire clear coat with 400 grit then mask the pink area off, spray the color and reclear the entire frame. Should be mostly invisible. If a chip goes deep enough to penetrate the new clear, blue and old clear, you'd still see the magenta but that's a pretty deep chip anyway.
I would have a pro do the spraying with automotive paints. DON'T RATTLE CAN IT!
That's all assuming you want to go to the hassle of all that and the expense. I did respray my 2004 TCR Composite but was able to do all the work myself. Resale will be totally changed also.
1 - 4 of 4 Posts
