1 - 7 of 7 Posts
In response to the fact that Kreitler (Ekosport) would not warranty a fan belt that broke at the weld I found a manufacturer that guarantees its welds for 2 years and at a better price.
42" fan belts are $9.00
72" roller belts are $13.00
These belts are made of extremely durable Cyclothane-A orange (85-A)
If your interested in purchasing a set e-mail me at [email protected]
John A. Martin
Interesting that you should post about it now. I figured out how to weld urethane belts better but my old belt (I think it's 7-8 years old) started developing new cracks. So I ordered 25 feet of clear urethane belt and made a new belt which so far has withstood my most intense interval workouts.
Technique is very important in welding these belts so I suspect they're not doing it right over there at Ekco. Maybe a new employee or some equipment gone bad. My belt's original weld never broke but it's cracking in many other areas due to age.
My rollers might need new bearings and I wonder if Ekco will provide any support. I can replace them myself for $5 each should they decide not to honor the warranty on other parts.
Hey Squint,
Do you use a Killer Headwind attachment? My welds hold seem to hold until I get cranking w/the headwind opened up even half way. Then the fan belt brakes again.
Anyway the engineer I talked to about these Cyclothane-A 85 belts says that if the weld is done right the belt will wear out due to stretch or break where damaged such as from a nick.
I tried clear polyurethane and it worked ok on my roller belt, but it squeaked annoyingly.
Good luck with your bearings.
Yes, I use the Killer Headwind all the time and at 1/2 open when doing some short intervals. So your 42" belt broke? What about your 72" one? After reading your post yesterday, I took my fan belt off of the rollers and inspected it. Unlike my main belt, it has no cracks in it so it should last for several more years.
I measured the main belt at 75" and the fan belt at 44", probably due to stretch. I cut my replacement belt at 74" and it seems to work fine. If it stretches over time, I'll just cut it shorter. If I were going to make a new fan belt, I'd probably start at 43-43.5".
The squeaking you experienced might go away as the belt wears, perhaps the way shoes squeak when they're new. I'm always listening to my MP3 player so I don't hear much when I'm riding.
I've learned a bit about welding urethane belts in recent days. I think the most important thing is to apply enough heat to the belt. The material will melt as soon as it touches the iron but I keep applying heat for several seconds. You'll see the stuff start to boil. The next most important thing is to quickly put the ends together and hold it for at least 30 seconds (longer, if possible) and then let it sit for a minimum of 30 mins. I don't try to align the ends in the moments after putting them together. I think that weakens the joint. If it's not aligned good enough the first time the ends touch, I pull it apart, reheat it, and try again. After it's cool, I trim away the flashing with nail clippers or scissors and then use a Dremel to grind it smoother. I also clean the soldering iron tip before doing a weld.
Welding these belts can be difficult. Apparently, Ekco has some difficulty with it.
No problem with the main belt lately. I bought a new one a few years back as my rollers are about 13 years old.
I made a jig and welded the fan belt this afternoon its holding so far.
The stretch is normal and depending on the type of belt acceptable stretch is between 8% and 12%.
At 43.5" you should still go with 42" for a cut length, or so says the belt Guru I'm working with.
Al did his homework well in the design of the rollers we've come to love and cuss!
Yeah, I saw the numbers at the website of the manufacturer of the clear belting I bought. If the belt eventually stretches enough so that it starts slipping or something, I'll just trim it shorter and re-weld it.
How did you make your jig? I had a few designs in mind that are more complicated than V-blocks and more similar to the plier-like clamps that the commercial welding kits come with.
My new belt survived another anaerobic interval workout just this afternoon. I think it'll hold up. It's just that the joint is a bit misaligned.
I just clamped two 1"x 4"s together and drilled between them just off center so as the bottom part would be deeper and hold the belt for heating. Then used deck screws to hold them together. The weld broke about 5 minutes into a full open fan workout.
I'm done welding.
I have two sets of belts coming in around Tues/Wed. For $9.00 and $13.00 I figure thats cheap reliability. Talk to ya later.
1 - 7 of 7 Posts
