I'm planning on replacing my brake and shifter cables on my Bianchi Intenso with 10 speed Shimano 105 group. I can confirm that the brake cable is standard 5mm and the shift cable is standard 4mm, but there seem to be some variances in O.D. for the brake cable ferrules. My parts bin has brake ferrules to fit 5mm brake housing but O.D.s are 5.5mm on some and 5.9mm on others.
The reason the O.D. is important is that the CF frame has internal cables and where the ferrules need to 'plug in" to the frame, they need to be the smaller outside diameter version. Also, the OEM ferrules, Bianchi implemented are silver alloy and for looks I think I would prefer to use a black ferrule, maybe plastic. Interestingly, Bianchi used black ferrules for the shifter cable housing.
If I order Shimano cables and housing, which I am likely to want to use, what can I expect to get for ferrules?
