Editor's Note: This article originally appeared on Mtbr.
Two years ago, CatEye wowed us with the 250 Lumen Nano Shot which featured a very small package for $100. Actual output was 200 in the integrating sphere. This year, the new light is the Volt 300 for only $60. The good news is the actual output is 349 Lumens in the sphere, so not only is it significantly cheaper, but it's much brighter as well.
So that's the real story here as it is an incredibly affordable light and it is bright enough for commuting or even trail riding. It can even be used on the helmet to complement the CatEye Volt 1200 mounted on the bar.
Form factor is not as nifty as the old Nano Shots but this still a handy flashlight style light that can have great utility around the house. It features a removable battery which can be replaced with a fresh rechargeable one for 'unlimited' run time.
Run time is an incredible three hours on the highest setting. It's sophisticated enough to sense a high powered USB source too so it can charge in three hours instead of six.
Specifications
- Price: $60
- Claimed Lumens: 300 Lumens
- Measured Lumens: 349 Lumens
- Measured MTBR Lux: 35 Lux
- Lumens per $: 5.82 Lumens
- Lumens per gram: 2.91 Lumens
- Time on High: 3:00 Hours
- Charge Time: 3:00/6:00 Hours (Can sense high powered USB charger)
- Mounted Weight: 120 grams
- Category: Flashlight/Commuter
Strengths
- $60 is a screaming deal for this light
- 349 measured Lumens is quite a bit above the claimed 300 Lumens
- Good value for the money
- Excellent CatEye quality
- It can be used with as a helmet light to complement the Volt 1200
- Light head has a lip to prevent rider glare and it has cutouts on the side to provide some side visibility
Weaknesses
- It's just barely enough for trail riding so it's more of a commuter light
- Square shaped beam pattern would be much better served as rectangular to offer better peripheral view
Mounting
The mount is the old school CatEye bike computer mount. It worked fine for bike computers and it was fine for the small Nano Shot light. Remarkably, it still does the job for the 120 gram Volt 300. Such is the foundation of the CatEye brand. They have simple, well-designed components that can do the job and more.
Mtbr Light Meter Measurements
This light measured 35 Lux on our ambient light measurement facility. The light output measurement is performed by placing a Lux light meter beside the light. Both are pointed at the ceiling (five feet above) of a dark room. This measurement uses the ambient light produced by the bike light.
Integrating Sphere Measured Lumens
This light measured 349 Lumens in an integrating sphere. Claimed Lumens by the manufacturer is 300 Lumens. The Lumen-hour graph below shows how the light performs over the first three minutes of its battery cycle.
Compare all Lumen Tests here »
Tunnel Beam Pattern Photo
The location is useful since it has walls and a ceiling that can display a bike light beam pattern. The walls have a lot of graffiti on them and actually show detail when they are lit up by a light with a wide angle. Cones and targets are set up with the far target set up at 120 feet.
Compare all Beam Patterns here »
For more information visit www.cateye.com.
