<table width="700" border="0"><tr><td>Yesterday I took off on a mostly unfamiliar route. I started in Calabasas, rode up Valley Circle to the Santa Susana Pass, took the pass to Simi, cut across Simi Valley and into Moorpark, then up and over Grimes Canyon to Fillmore, where I turned around, went back over Grimes Canyon, through Moorpark, then straight down into Thousand Oaks, then back through Westlake Village and Agoura and into Calabasas.
Even though I Topo'd the route, it was much harder than I thought it would be. 78 miles, 5200-ft of climbing. It just seemed like non-stop climbing.
I did the first 20 miles of this route last year, as well as the last 10 or so, but the whole middle chunk was foreign to me (as far as riding goes). I love finding new routes.
<hr size="1" width="600">
The elevation profile. That second peak is northbound Grimes Canyon, and the descent after that was A LOT of fun.
</td></tr></table>
<table border="0" width="700"><tr><td>
Starting up Valley Circle.
See that white string? True fact: Orthodox Jews will surround certain neighborhoods with said string so that they can consider it an enclosed area (i.e. house) and therefore circumvent various Shabbat rules, such as pushing a stroller to shul, etc.
Going around Chatsworth Lake.
I've finally figured out the routing kinks with the 705. Basically, they don't like using GPX files anymore, which makes sense since that's a universal format.
You can only upload two routes at a time with a max of 100 waypoints. If you use Courses (not a universal format) you can upload as much as you want.
I took this same shot last year, just before climbing the Santa Susana Pass.
Climbing.
Almost at the top. Maybe. Maybe not.
This is all I saw for 7 or so miles.
An abandoned store in Simi Valley.
At the western end of Simi.
Climbing up Tierra Rejada, between Simi and Moorpark.
In Moorpark, starting the gradual climb up Walnut Canyon.
Headed toward the start of Grimes Canyon.
Starting up Grimes (aka Hwy 23).
*pant*
Still going.
HItting the top and about to start a killer descent.
Beautiful scenery out here ...
... except the part where miners have carved away half the mountain.
</td></tr></table>
</td></tr></table>
Climbing.
*pant*
Still going.
</td></tr></table>
