1 - 12 of 12 Posts
I got a pair of Forte CR150ti pedals for a great price($42). But I just noticed than the rider weight limit is 175lbs & I'm 210lbs. How crucial is the limit? Should I just take them back or is it not a big deal? Do all pedals have rider weight limits or just those that have a titanium spindle?
is it worth the risk?
Think about what's going to happen if the axle snaps off. It's likely your groin is going to make a very unpleasant impact with the seat or top tube. Then, there's the whole crashing part. Is saving an ounce worth that?
There have been several posts here about injuries sustained when Ti spindles break. If anything, you should be conservative here, and assume that weight limit is generous. It is simply not worth the risk of shearing a pedal in an out-of-the-saddle effort and going down in a heap of hurt.
I don't see that pedal on Performance's web site right now, but I'm guessing their about 275grams for the set and around $75. Perormance has a good return policy; return the Ti's and order a set of their Carbon's with cromolly spindles for $25 more. They weight 260grams for the set.
True, thanks. Well know I guess I'll start lookin for pedals again. I didnt want to spend the money on the Ultegra pedals. But since I have the entire Ultegra drivetrain might as well get the pedals too.
Thats a good idea. I just hope I can walk out of Performance w/o buying anything else but pedals. Knowing me I'll buy like 5 things I didn't plan on, lol.
So heres a really simple rule of thumb: If you have to ask if a piece of gear is too light for you, it is.
Why do you want to risk putting yourself in the Emergency Room for 50 grams?
Only Look, Campagnolo, and Time don't have a weight limit on their titanium spindle pedals. As a rule of thumb, if you weigh way over 200 pounds and are a gear masher, do not buy titanium pedals.
I think the weight limit on Performance ti pedals is just under 190 pounds.
Pedaling style
If you never stand up and never sprint hard, then the weight restrictions are not an issue. Everybody I know stands up.
Its not a good idea, its not so much the spindle shearing off its the 9 mm nut inside the pedal body that holds the bearing . when that puppy breaks( the end of the spindle is only about 5mm with threads cut into it) your foot goes down but it still has a metal pedal stuck to the bottom and at that speed you may as well be on ice. Can you say groin injury, I know I can. thank god I was just getting going. yes I am 240 on pedals that stated 200 as a max weight and I thought the same thing , I will be restraighned I wont mash. ooops!
1 - 12 of 12 Posts
