1 - 8 of 8 Posts
I've been testing bikes for a couple of weeks now, and I've been able to get the various LBS's to dial in the bike so that I'm very comfortable riding in the hoods, however, I can never get really comfortable in the drops. I often feel like I'm reaching too far to reach the shifters. Is this just a fact of riding in the drops, that you *are* reaching more than in the hoods?
the distance is more, but you should still be able to shift while in the drops. You dont want to have to push up to the hood to go to a higher gear at 35mph:eek:
Since I am kind of new to road riding, I also found riding in the drops a little different at first. Now, I can ride in them for a while. It has to do with your flexibility also.
I also descend all the time in the drops. I find I can get my outside foot down easier and lean the bike more in turns. The brake leverage is way better too. I ride mtb mostly. So, one finger braking is all I'm used to.
Cycling induced anoesis
If I'm understanding your post correctly, the issue is not with your flexibility or overall comfort riding in the drops, rather finger reach to the levers. If that's the case, you may benefit from a shifter that has adjustable reach. I know that Sora and Tiagra offer that, but Specialized also offers shims that you can install in 105 (and up) models that will bring the levers closer to the bars.
Not quite "finger reach", but to be a bit more specific... I'd like to be able to ride in the drops with my hands towards the front of the drops with a fairly straight arm. However, I find that I need to bend my elbows quite a bit in order to have my hands at the front. Seems that when I'm towards the front of the drops my forearms come pretty close to rubbing against the horizontal (or top?) part of the bars.
malanb was right. Some drop bars have a shorter reach, as well as a shallower drop. they also come with various kinds of "anatomic" bends. You may need to look around at different bar designs to find one that fits your style better. A change in the angle of the bars, and the placement of the levers, may also solve this issue.
What the what???
Sounds like a question of finding the right placement of the shifters on the bars. Adjusting the position of the shifters along the curve of the bar should give you a happy medium where the hoods are still comfortable and the levers are easier to reach while in the drops.
You're supposed to keep your arms slightly bent at the elbow when in the drops (as well as tops and hoods, for that matter), so it may be a flexibility issue or simply riding in the drops is not entirely comfortable for you - fairly common to anyone new to road riding.
For future reference, you don't want to ride with your arms straight because doing so tends to transmit road irregularities/ harshness up through your hands/ arms resulting in sore arms/ neck/ shoulders. Keeping a relaxed upper torso is key to maintaining comfort.
Seeing as you've been testing bikes for a couple of weeks (thus have been exposed to several bars shapes and shifter placements) I don't think this is the primary cause of your discomfort. That's not to say that in the myriad of bar choices on the market one isn't better for you than another, but right now I think it's more a 'getting acclimated' issue.
1 - 8 of 8 Posts
