Cross-post from the wrench forum...I just took delivery of an '08 Ridley Excalibur (woohoo!) and ran across a stumbling block on assembly. The integrated headset bearing drops right in on the top, but with the bottom bearing, the tolerance is real tight--almost as if it's supposed to be pressed into the frame. Can anyone confirm that the bottom bearing is in fact supposed to be pressed in?
With every integrated headset I've installed before, the bearings just dropped right in. The Ridley headset is proprietary (tapered so it bigger at the fork crown), so assuming the install is different? I have a home-made headset press that I'm not sure is up for the job given the large size of the bearing (1 1/2 inch)...anyone have any experience assembling one of these?
THANKS!
THANKS!
