1 - 4 of 4 Posts
Is there a "right" (or wrong) mfg's stem to use with carbon bars?
Eg: One certainly doesn't want the carbon to be scored by the stem clamp.
So I wondered if it's better to use some mfg's stems for carbon bars.
And if any stems should be avoided.
I couldn't give you any specific brands/models off the top of my head, but generally if you avoid sharp-edged CNC machined clamping surfaces and install carefully you won't get any scratching or damage to the carbon (just remember to check the faceplate bolts' torque, you don't want to overdo it, but you want it to hold).
Stem treatment
Also, you can dress the sharp edges of a stem clamp, both for the bars and the steerer tube. This is a good practice if you have concerns about the stem cutting into the bars or steerer.
where to find tourque specs?
Thanks.
I've looked but can't find any torque specs.
fwiw I am using the Modolo KX-Carbon Curvissima bars
anybody have this data?
1 - 4 of 4 Posts
