1 - 2 of 2 Posts
I'm planning to build up a set of carbon wheels for next season - 20/24, CX-Rays, White and/or Shimano DA hubs with 50 - 60 mm deep rims. Any preference between the 2 rims? Weight is not an issue since any ride/race around here has at most a few hundred feet elevation change for a 50 -60 miler.
I know people who have both and like both. I'm hearing good things with the new Flo's too! If I was choosing between the two I'd go with the Flo's on rim shape alone. Even if you don't go tubeless, the tubeless rim holds the tire on better in case of a sudden lose of air. Flo's with white ind. hubs would be a pretty sweet setup. Did you consider a full flow wheel Set?
1 - 2 of 2 Posts
