Does anyone know if these freehub bodies are interchangeable? I already have the Campy hub, and it comes apart very easily, and the freehub body slides out independent of the axle. Is the Shimano body the same, or is it a standard issue Shimano body that must be removed with a massive hex wrench? I ask because, if they are identical, I'm going to buy the set and swap the freehub bodies.
The main differences I see in the photo are: steel axle end on the Shimano hub, whereas the Campy hub has a one-piece aluminum axle, and hub body shape.
<img src='https://i13.ebayimg.com/04/i/06/51/24/45_1.JPG'>
<img src='https://bikewagon.com/ebaypics/ritchey/DSCN4736.JPG'>
