Over the weekend, I swapped my Rival group from an older bike to my current road bike, replacing the 105 group. Everything went fine except I am having nothing but trouble adjusting the front derailleur and at this point I'm at a loss of what I should try next.
I've adjusted it to the usual spacing - 1 to 2 mm between the tallest tooth on the chain ring and the derailleur, cage parallel to the chain rings, set the low-limit screw to about 1 mm between the chain on the cage in the small/big combo, and high-limit screw to 1mm in the big/small combo. However, when I try to shift from the small to big chainring, the derailleur doesn't engage the chain enough to shift. It's just barely rubbing on it. I've never had this problem before. Using the above method, I've always been able to get the FD to work, piece of cake. However, this is a new bike (Giant Defy 1) and there could be something I'm overlooking.
Does anyone have any suggestions for what I should try next?
Thanks.
Thanks.
