1 - 14 of 14 Posts
I bought a frame at the flea market a few weeks ago and I am still in doubt at to the type of bike the frame is for. I believe it is for a road bike, but it doesn't really look the part. The frame is all aluminum with a removable rear derailleur hanger. The frame has a large triangular/diamond shape to the downtube.
Here is a picture with all the measurements. The brake dropouts are 280mm from the axle centerline. The rear triangle measurements are from the axle centerline.
Thanks for the help,
Ian
Anything on 2 wheels
Ian
128mm axle spacing is non-standard.
https://www.sheldonbrown.com/frame-spacing.html
I'd use it with 130mm hub, therefore making it a road bike...
duh...
duh...
w98seeng said:
why is it a BS pic?
w98seeng said:
I removed the canti bosses when I was fixing up the pic with the measurements.
news flash... road bikes typically do NOT have canti studs
duh...
PissedOffCil said:
As far as I know, old road frames usually have canti studs but to make everybody happy let's say it a CX frame... whatever...
but old road frames certainly didn't have "integral headsets", formed alu tubes, etc. so this ain't an old road frame
plus, a 50cm frame with a 54+ (horiz will be longer) TT?! no, it ain't a road (or cx) bike, or at least it ain't a typical one
1 - 14 of 14 Posts
