Do you mean cartridge bearings?Hidas said:Any suggestions of high quality road hubs with sealed bearing in the price range of 100-150 US dollars, for both front and rear?
I'm pretty sure that the Ultegra 6600 hubs are loose bearing hubs, just like every other Shimano hub I've owned.chas0039 said:Of course he means cartridge.
Most hubs I see these days are cartridge or sealed, meaning that they have a single, pre-adjusted unit for the bearings rather than the older cup and cone loose bearings. It would be helpful to specify more about what you were looking for such as Campy or Shimano cassette or the number of spokes, road or track, etc. Also you could add why you want to build rather than just buy the whole wheel, often less expensive.
The Shimano Ultegra 6600 series fits the bill for price and they have a decent range of spoke choices.
Becky said:I'm pretty sure that the Ultegra 6600 hubs are loose bearing hubs, just like every other Shimano hub I've owned.
By your definition they don't. As several posters have commented, traditional cup and cone hubs are superior in most ways provided they are kept in adjustment. The only advantages cartridge bearings have is ease of assembly and lack of consequence to poor maintenance. I have several pairs of older Campag and Shimano hubbed wheels that are still running clean & free a decade or more from new.chas0039 said:Of course he means cartridge.
Cartridge bearings are often called "sealed bearings." In this case "sealed" does not mean sealed from the elements, but "sealed from the user" who will not be able to maintain the bearings.ultimobici said:By your definition they don't.
I don't need a lesson in cycle terms.laffeaux said:Cartridge bearings are often called "sealed bearings." In this case "sealed" does not mean sealed from the elements, but "sealed from the user" who will not be able to maintain the bearings.
Bottom brackets are the same. Cartridge, or sealed bottom brackets, are not serviceable. Where as cup and cone, which still have seals, are serviceable.
If your budget is up to $150 have a look at Shimano. Cartridge bearings are not an improvement just a manufacturing shortcut. I have Dura Ace from the 80's that are still going strong long after similarly priced cartridge bearing hubs have given up the ghost or needed new bearings. Both are on their original cones and balls, only the grease has been replaced. Same thing with my Campag hubs.Hidas said:Any suggestions of high quality road hubs with sealed bearing in the price range of 100-150 US dollars, for both front and rear?
I've had excellent luck with cartridge bearing hubs, including Suntour, Specialized, Mavic 550s, and Ksyriums. I've also had excellent luck with cup-and-cone hubs. I've also trashed both kinds.Richard said:While I don't think there's a better hub out there than a cup and cone Campy Record, a quality "cartridge" bearing hub can be quite acceptable. The hub in the front wheel of one of my bikes is a Mavic 550RD, originally purchased in the mid '80's. It is now laced into it's third rim, has at least 50,000 miles on it, has never been serviced, and that sucker spins as smoothly and quietly as the day it was new.
No worries. And FWIW, I totally agree with you about cup and cone hubs. Easy to maintain, and easy to find new bearings. No weird proprietary stuff...chas0039 said:Sorry, my mistake about the Ultegra hubs. I had some bad information from an LBS. For the record, I am NOT a fan of anything but cup and cone hubs. I much prefer the ability to service and replace parts without the problems related to "special" cartridge bearings.
