Rocky Mountain Solo
Sam Schultz rides Missoula to Arizona, USA. Photo by Margus Riga​
Meet the new Rocky Mountain Solo, a bike the Canadian brand says is meant for riding anywhere and everywhere. With expansive tire clearance, the ability to run a full-length dropper post, and a 1x specific frame, it's designed to be a versatile bike for any adventure.
[vimeo width="610" height="254"]https://vimeo.com/258209732[/vimeo]
The Long Way, starring Rocky Mountain athlete, Sam Schultz.
Rocky Mountain Solo 50
Built for the pursuit of adventure, the all-new Solo doesn't stop when the pavement ends. From your familiar weekly rides to taking a chance off the beaten path, the Rocky Mountain Solo is a bike for any adventure. Here's a rundown of key highlights:
Rocky Mountain Solo
Progressive clearance compatibility
A unique yoke design of the frames' rear triangle allows greater tire clearance for up to 700 x 40c tires, and more chainring clearance from the driveside stay.
Rocky Mountain Solo
Innovative carry features
Rocky has integrated several carrying features that give you the option to bring everything from water for the day, to accommodation for the night. This platform features multiple water bottle mounting options, rear rack compatibility, and mounting bosses on each leg of the fork for all of your gear.
Rocky Mountain Solo
Ultimate ride comfort
To help with control, comfort and ride quality, Rocky used a tapered head tube, 425mm long chainstays, and a 12x142mm thru axle to create a ride feel that inspires confidence. They've designed this bike to be compatible with a full-length dropper post, allowing for both efficient climbing and descending.
Rocky Mountain Solo
Technical Details
  • Multiple water bottle bosses for carrying options
  • Three-Pack cage bosses on each fork leg
  • Rear rack compatible frame
  • Massive tire & mud clearance
  • 12 x 142mm thru axle for increased wheel strength
  • Unique yoke design to accommodate both tire clearance and chainring clearance
  • 1X specific
  • Internal cable and brake routing
  • Tapered head tube
  • Chainstay length optimized at 425mm
  • Dropper post compatible
  • Sizes: XS-XL
  • Weight: Solo 70 - 9.5kg; Solo 50 - 10kg
Rocky Mountain Solo 70
Solo 70 ($2549)
  • Alloy Gravel/Adventure Frame 1x only
  • Wide Range SRAM Force 1x drivetrain
  • Dropper post ready
  • High performance Maxxis Tires
  • Fits 700 x 40c and 650b x 2.20 tires
Rocky Mountain Solo
Solo 50 ($1899)
  • Wide Range SRAM Apex 1x drivetrain
For more information, visit www.bikes.com.
