1 - 12 of 12 Posts
I've got a set of circa 2000 blue Rolf Vector comps that I want use on a a Vintage Olmo restoration. These wheels look sweet against its blue ano cranks and stem so I really want to use them. Trouble is these vectors have shimano 10s freehub and campy version is not available. Bike is Italian so drivetrain has to be campy (Mirage 9 spd). Any idea's on how to make this work? Who actually makes these hubs? AM classic and other brand conversion cassettes seem to be a thing of the past. Thanks IMG_0425.jpg
Many moons ago, I had Campy record 10 speed & several sets of wheels, I had a Shimano set that I replaced all the Shimano cassette spacers w/ Campy 9 speed spacers.
It worked great. When setting it up, center the derailleur on the 5th cog (with shifter in 5th) I was told it wouldnt work, worked great, gave me no troubles. The Shimano 9 speed cogs actually worked better than Camps 9 speed cogs .
those Primato cassettes appear to be either campy or shimano, not a conversion cassette . Thanks for the links though.
thank you. Seems like this is the only option that will work. Cheers
Discussion Starter · #9 ·
Local to me Craigslist has a set of Rolf's for sale with a Campagnolo freehub that's been up quite a while-not sure if older 9 speed used the sample splines.
https://washingtondc.craigslist.org/doc/bop/d/baltimore-rolf-700c-wheelset-campagnolo/6842847490.html
thanks those look decent. Think I'm gonna try the homemade cassette stack first. Apparently the version I have didn't even have a campy freehub option so not sure I'd be able to swap freehubs with those CL wheels.
Discussion Starter · #10 ·
got it all worked out. SRAM cogs with campy 9s spacers. Was only able to fit 8 cogs with @ 9s spacing but that's plenty for this retro rig. Shift quality not bad at all. Thanks for the help (except mr cxtool)
Hi, I'm actually face to a Rolf vector comp freehub. My customer complains about buckled cassette. Unfortunately I can't find any documentation on that hub. Do you have any manual or experiences to share? Thank you.
1 - 12 of 12 Posts
