1 - 5 of 5 Posts
gastarbeiter
lower the pressure in your tires
mrcrabbiepattie said:
where could i get some roller resistance?
anyone with suggestions
Cheap trick.
Some cardboard inside the wheels simulates real-world air resistance fairly well. Takes less than you think to set up a nice drag once you get cranking.
Heat warning
BeeCharmer said:
A towel under the back roller, if you want cheap.
This is OK if you have metal rollers, but could cause problems with PVC rollers if the heat builds up too much. You could warp the PVC in extreme cases.
1 - 5 of 5 Posts
