I test rode a couple Roubaix's today. An XXL (61cm) with a 110mm high rise stem, and an XL (58 cm) with a 120mm high rise stem. The tech was trying to get the distance from the seat post to the bar to be the same on both setups. With this setup the bar was about level with the seat on the XXL and about 1/2 inch below on the XL.
I'm inclined to go with the smaller frame as I erred with a too big frame on my last bike. The smaller bike is an 05 closeout with 105 brakes and Ultregra shifters vs unknown brakes and 105 shifters on the 06 XXL. The asking price for both is the same.
The formulas to determine frame size that I have seen indicate I should be in a 60cm frame, right between the two sizes available. I'm 6'1", 200lb, 35.5" cycling inseam with 37" arms.
Since the frame/stem combos on both seem to fall within the norm, should I be reasonable comfortable on both? is there any benefit one way or another when choosing to go smaller frame/longer stem vs larger frame/shorter stem? And would 1/2" differnce in drop between the two setups be appreciable to relatively new rider?
