Looking for opinions on running 25c tires at slightly lower pressures than may be indicated on the sidewall for comfort. For me, one of the main reasons to go with 25c tires is for a bit more comfort than 23c and that is accomplished in some respects by lowering the pressure 5-15 lbs especially when using a wider rim.
I have two sets of new 25c tires: Vittoria Rubino Slicks (100-130 psi recommended) and some Performance Forte Pros (110-130 psi). I'd really like to run these at ~95 psi or so. I realize that there might be some issues with bead seating at lower pressure.
Thoughts?
Thoughts?
