1 - 4 of 4 Posts
I picked up a used S-Works Tarmac SL2 frame module recently. I am wondering how the crank / bottom bracket come apart. Any help would be great. Thanks.
There is a cosmetic cover screw that needs to be removed from DS of the crank. After that there is a 6mm, I think, bolt that holds the crank together, you'll need a deep 6mm allen and lots of torque to get it loose.
Cycling induced anoesis
1 - 4 of 4 Posts
