1 - 4 of 4 Posts
Does a fork from a (Time VRS) size L frame fit into size M frame?
It seems the length of the fork legs are the same, but what about the QUICKSET (integrated headset) (or other dimensions of the fork)?
According to the geometry chart the trail, rake, and head tube angle are the same, but the head tube lengths are of course different.
I have a Time frame (size L) where the rear triangle was damaged, and there might be a chance to buy a size M frame (not sure if it would really fit me) without a fork, so I'm wondering if I could reuse the fork.
I'm no expert, but I don't see why this wouldn't work.
I forgot about the Quickset issue -- even though you mentioned this in your message. I would assume the threaded adapter that is glued on the fork steerer would be in the wrong location. I have no idea how feasible it would be to detach this and secure it in another location.
Thanks for the update; by now I found some instructions for Quickset maintenance with a picture of the fork showing the part which is glued on.
So this isn't worth the effort to swap to a frame with a different headtube size.
1 - 4 of 4 Posts
