1 - 20 of 52 Posts
· Number 2 on the course.
Took delivery of one today. Thought I would post some unlisted details that might interest anyone looking to jump on one of these since they are now $249 and there are %20 discounts floating around.
http://www.performancebike.com/shop/profile.cfm?SKU=25729&subcategory_ID=3020
Weights:
Frame (60cm): 1670g
Fork: 650g
Frameset*: 2400g
* Includes 60cm frame, uncut fork and FSA headset (with all small parts). Does not include the provided seatpost clamp, because I won't be using it.
The frame is made in China. I assume the fork is too. The paint seem nice -- too bad about the name. The welds damp vibration like a scalded roll of bubblegum flavored dimes.
Will update as I swap parts over from my Soma.
Fun fact: the brake set I will be using sells for more than the frame set.
· Fast No More.
That's like the ultimate sandbagging tactic. Roll up to the line on a Scattante and then smoke 'em for the next hour.
The look on their faces should make up for the name on the downtube.
Yep, race bike. Weight as pictured is 19.75#. Of course, that is without pedals, but the heavyish clincher wheels will be swapped out for tubulars so I imagine the race weight will be somewhere in the 18.5-19# range. No lightweight but not too bad for the money. Could probably loose another pound by swapping out the Nitto bars, steel rail saddle, XT RD etc.
I think the frame would save you about a pound over the Crosscheck. The fork weighs much less than those stock lugged forks, but is the same as the Kinesis.
Discussion Starter · #10 ·
Well you have the Kinesis fork so your only incentive is the ~1# weight advantage of the frame. Unless you have a fit issue with your Crosscheck (which I had with the Soma), it is worth looking at where else on the Surly you could spend $200 to achieve the same weight loss or an equivalent performance advantage. Tubulars? Spare set of clinchers? Treads for all conditions?
Jeeesh...Now you're starting to sound like my wife...lol :thumbsup:
Thanks for the chart PBB...I was hoping the TT of the XL was just a bit longer, closer to 60at least. Hmmm...maybe I can make up the slight difference. Problem is that I'm a mountainbiker so any road/cross fit is going to feel strange after all these years.
Ill be taking delivery of one of these frames tomorrow, I ordered it this past weekend with their two-day 20% off code. I have a question though, does it come with the front derrailleur pulley? I'll post a pic tomorrow evening with its preliminary build.
Any other codes to help defray the costs?
1 - 20 of 52 Posts
