1 - 7 of 7 Posts
Which silver finish, anodized or polished, is a better match for silver 2006 and older Campagnolo components, Cinelli 1a stems, Nitto seatposts, 6500 era Shimano, and other components with a classic shiny silver finish?
Even when new classic silver stops short of a mirror finish
Bicycle part Metal Steel Household hardware Metalworking hand tool
Schmidt's polished is actually polished, and silver anodized looks a little more satin in on-line photos although I can't find a side-by-side front and other rear-hub paring picture anywhere
Product Photograph Red White Circle
Adorable Furry Hombre
IIRC the only satin finish alloy parts back then (2006 and before) were cranks and calipers...everything else was polished/shiny around that era.
I'd probably pick the Ano finish, in any kind of weather the polished finish will be a dirt/dust/water-spot magnet.
Depends on you and the bike. I don't like mixing the two on a bike. My '98 LeMond Zurich 6500 to me would look strange with high polished components while my Colnago and Pinarellos would look odd with a satin finish. Polished needs attention from time to time and if let go will not look good and once the anodizing is damaged or wears it can look shabby w/o a way to easily improve.
What rear hub are you going to use? Personally I'd match the hubs.
I've got a polished Schmidt hub paired with an older polished Campagnolo rear with Grand Bois polished rims and I'm quite happy with how they turned out.
Discussion Starter · #5 · (Edited)
A PowerTap SL+. I'm trying to match the finish, but haven't managed to find any sort of side-by-side picture with other hubs that'd identify which is closer. Polished is definitely shinier, although anodized looks a little less glossy than is typical.
With road salt I'd go with anodized, although fortunately I live in a temperate climate.
Rear wheel: PowerTap SL+, retro-reflective HALO powder coated Velocity Fusion rim, 32 2.0/1.5 DT Revolution spokes, alloy nipples, 1997-2006 Record skewer. I'll do the same up-front apart from the hub.
Bicycle tire Wheel Bicycle wheel rim Bicycle part Spoke
I thought I'd find some one's artful wheelset pre or post build pictures online, but my google-fu was not strong enough. Like this:
Metal Iron Cylinder Nickel Pipe
Don't know if this'll help...
Bicycle tire Bicycle Bicycle part Bicycle frame Bicycle accessory
I think I would go polished with that hub. I guess you could go with the polished black hub, I've just never been a fan of black hubs.
I used to have a wheel with that hub but it went south and Cycle Ops upgraded it at a darned good price, with a trade in. The replacement is black and it's got more of an all business look to it.
Bicycle tire Bicycle frame Bicycle wheel rim Bicycle part Spoke
Another, closer look at the SoN, jst not a vry good one...
Bicycle wheel rim Spoke Bicycle accessory Rim Bicycle tire
1 - 7 of 7 Posts
