1 - 1 of 1 Posts
changingleaf
Schwalbe Pro 1 700 x 25 Tubeless Easy Microskin review
I mounted the Schwalbe 700 x 25 Pro 1 tubeless easy tire on a newly built Boyd Altamont rim.
Measured tire weight: 260g
Size measured on the Boyd Altamont at 100 psi:
27.3mm wide
24mm from the top of the rim to the top of the tire.
The tire mounted by hand fairly easily.
I inflated it with a compressor and a air-bob inflator. The made several snaps before fully seating into the bead at about 100 psi.
The Tire holds air excellent with a properly taped rim.
The casing and tread on the rubber feels durable. It's a well made tire and fits the Boyd Altamont rim perfectly. Some miles will tell how long it lasts.
1 - 1 of 1 Posts
