Steve-O said:Is that the North Branch Trail in the north 'burbs of Chicago? (Background looks very familar)....
The brake levers you mean ?lazyrack said:Steve, I see that you have the front brake neatly attached to one of the brake calipers, but what is the other brake caliper connected to?
-L
Schweet! Nothing like a cream-colored head tube to give a bike some class. - FBBslowmo1 said:I think I will use that, and Steve's, for inspiration for my Traveler, except with a metallic ruby and cream color scheme.
Youz guyz are scaring me. Please be VERY careful when you mess with stems. It doesn't take much of a stress riser to cause a failure which could end your life. You can find new and used stems in almost every shape and size. I encourage you to look at what's already available before you starting making chips fly.slowmo1 said:My dad said it used to be a fairly common trick to cut and weld a neck onto another stem, so that the diameter and the reach would be right. I have another Sakae stem that may be the right diameter, but the same length as the current one. I could explore the option of having my FIL cut and weld the two together. A seatpost with an angle could help some, too.
There have been many, many .833 stems made over the years. Have you checked out eBay? You might also want to post queries on:slowmo1 said:My understanding is that these particular stems have a proprietary diameter of .833 and are very hard to find. My stem is too short. What options should I be pursuing?
