Hello all,
I am currently building up a Colnago Extreme Power frameset with mostly SRAM
Red components, the exception being the front der and crankset, which are 2010
Force. This frame has an Italian threaded BB shell (obviously), the shell was
professionally faced and has an exact width of 70mm. The install of a Blackbox
ceramic BB went fine and with no issues, or so I thought. Being Italian threading,
the drive side outboard bearings have an issue with loosening while riding. Fine,
I fixed this with some Threadloc (blue). My first crankset was defective and was
replaced by SRAM under warranty. I have a continuing problem with a metallic
scraping noise that appears only when riding. I've removed, cleaned, relubed and
replaced the cranks a half dozen times and the noise goes away for about 20 miles
before returning. There is no side-to-side play in the cranks. I've tried 3 different
ceramic BBs and one Team GXP BB with no change in the noise. Everything is torqued
to spec with a high quality click-type torque wrench.
I've checked the chainline - it's fine. The chainring bolts are fine (and, of course,
they wouldn't respond to a cleaning and relubing of the crank axel and BBs).
I'm about stumped and wonder if anyone else has had a problem that acts
like this?
Oh, I've seen the video posted showing a SRAM BB that made a scraping
sound. His problems seemed to be solved by cleaning and lubing the parts.
I've tried this several times with no lasting effect.
Thanks in advance for any help!
like this?
