1 - 11 of 11 Posts
Premium Member
If it's cartridge style BB, use a skewer w/ a quick release to hold the BB tool in place( the spindle should be hollow).
I'm going from memory but I think you need to use a rear skewer. A front is too short..
Put a big wrench on the BB tool and wack it with a hammer....Just remember drive side is reverse threaded..
I've used this method for years and it really works and saves the skin on your knuckles....
Brick Tamland said:
I need to replace my bottom bracket (shimano, cartridge-style, square-taper) and it appears to be seized.
Any suggestions?
WD40
Or I have found that I can seemingly get alot more torque using a socket wrench attached to the bottom bracket tool than with just regular wrench.
Banned forever.....or not
Lots of medium taps are better than one or two big hits.
Grey Manrod
Discussion Starter · #10 ·
Hey, thanks all for the replies. I couldn't find a piece of pipe suitable to my needs, don't currently have a bench vice and I was getting p!ssed. Three lb mallet wasn't doing the job, and I started worrying that I was going to break something. So, I took it to the LBS and let them deal with it. Took 'em a while, but they got it. A bargain at eight bucks...
1 - 11 of 11 Posts
