I have never seen your friend or anything but it seems fairly normal. Do you know if these are the dimensions of the size cycle or (if you friend is ordering a custom bike) are these the dimensions from Serotta? the size cycle numbers are not what you look at when you use it. They simply show the relationship of the position. For example, if the stangle is 73.5 and the saddle is all the way forward on the rails, then you can slacken the ST to 73, leaving the saddle in the same position (retaining the same KOP) and have the saddle in the middle of the rails.
There is nothing that jumps out there as odd. The ST angle is more for the KOPS than anything, you make a frame more stable/relaxed/twitchy other ways (CS length, fork trail etc.)
As far as the Saddle height to pedal measurement, i am not that familiar with it, but unless you were at the fit, its really hard to determine why the fitter/rider ended up with the numbers they did. It could be that thats where the rider was most comfortable, maybe if it was any higher his hips would be rocking side to side and fitter decided to lower it.
If this is for a custom frame, when you fit someone, you design the frame so it is neutral (saddle rails in middle, stem length not too long or too short, 2 cm spacers, etc) so that as the rider's body changes, the bike can change with it. I knew a guy who stupidly got a custom bike with no spacers, sure enough when to change position he couldn't because there was not enough lee way in the front end.
The fitter does have a lot of influence, it is a science up to a point, than experience comes in, the ability to "read" the body as it rides a bike etc.
Hope my slightly off-topic post has helped.
