I am going to (have to) replace my BB cups (the finish is popping off because of corrosion underneath, probably from sweat getting beneath the finish [Rant On]Seriously guys, this is your top-of-the-line group, with a couple of measly cups going for 40 bucks a pop. For that kind of money, you might expect the finish to last more than a year, just like any other $5-set of cups[Rant off]).
Anyhow, so I thought I might as well service the BB bearings while I am at it.
I have two questions:
- What is the best way to clean the bearings? Just wipe them off with a dry cloth, use chain cleaner, some other solvent? Use a brush?
- What lubricant should I use for re-lubing? Grease? Which one? Some oil instead of grease (I seem to recall Campy saying that you can lube the CULT bearings with oil rather than grease)?
