I am trying to determine whether I will need a setback/offset seatpost for a custom frame I am getting. The framebuilder recently sent me the proposed geometry and he has indicated a 72.5 degree seat tube angle. I have never had a frame with such a shallow seat tube angle. My two frames I have are 73 degree, and I use a 25 mm setback/offset seatpost, with the seat sitting squarely centered on the post (neither jammed up forward nor back). My setback (tip of the saddle to center of bottom bracket) is 91 mm.
As I have the opportunity to purchase a hard to find seatpost, I am trying to determine if I will need a setback seatpost with such a shallow seat tube angle. Does 1/2 degree make that much difference on setback?
Many thanks in advance for any insight you can offer.
